01-27-2018 15:42
01-27-2018 15:42
I just bought my fitbit, i think 1 week or 2 weeks ago. And its great so far! I got no issues! But last night i left it charging on 40% battery and fell asleep. I think i put it on charge at 10 or 11pm and fell asleep. And i just woke up at 7 to remove it!!!!!
Will it affect my fitbit’s battery life or does it have to be a habit in order for it to get ruined? And not just once?
what you guys think?
Best Answer01-27-2018 23:38
01-27-2018 23:38
I wouldn't worry about it. I always charge my Fitbit's over night, never had an issue with battery performance.
Best Answer01-27-2018 16:10
01-27-2018 16:10
Hi, @Beamar1995, I would not worry at all. Modern devices like Fitbits have built in protections against overcharging. As long as your battery does not get hot you should be fine. More importantly is always to be sure that if you use a wall charger it is UL/ CE certified.
01-27-2018 23:38
Best Answer06-01-2018 03:37
06-01-2018 03:37
nice to know! thanks ! I always fall asleep after plugging it in ahahaha a
Best Answer10-11-2022 08:09
10-11-2022 08:09
I did the same thing but my versa two Fitbit has not worked since then. I’ve tried the troubleshooting ideas without success. If anybody out there has a sure way of what to do, I’d appreciate your responses. Thank you. Tim
Best Answer10-17-2022 11:39
10-17-2022 11:39
Hi there @TimCain. Welcome to Community Forums. @Beamar1995, it's good to have you back.
Thanks for the help and support @Julia_G and @N8teGee
I want to inform you that currently this specific device is under recall. For more information about our voluntary Safety Recall of Fitbit Ionic Smartwatches, please visit our webpage at help.fitbit.com/ionic I am going to close this thread to keep the Community organized.
@TimCain I would suggest you address your questions and comments regarding the Fitbit Versa 2 in this board, where you can find answers for your device.
Have a good day.
