03-14-2018 04:27
03-14-2018 04:27
I just received my Ionic yesterday after my Surge notches broke on my band.
I was sooo excited until this morning where I still have not been able to sync Pandora!!! This was one of he reasons I chose this over Apple Watch because it works independently of your phone.
Now I’m reading this is just the beginning of the horror with the ionic. I may need to go to Apple and miss out on the sleep mode and 5 day battery life for a watch that’s works the way it was designed
Best Answer03-15-2018 05:22
03-15-2018 05:22
Welcome to the Fitbit Community @DivineLove, it's nice to have a new member here! I'm sorry to hear about the inconveniences you've been having when syncing your Pandora Stations to your Ionic. Don't lose the hope my friend, I'm here to help!
I'd like you to restart your tracker and double check you're following these steps to download the stations. Have you gotten any error message when trying to sync Pandora with Ionic?
Plug your watch into the charger. Stations download automatically when the watch is charging and in range of your Wi-Fi network, or tap Force Sync Now in the Fitbit app to add the stations to your watch.
If the issue persists, here is what I my sister did to get a Pandora station downloaded (she was about 2 feet away from the wireless router):
Let me know if the above steps work for you. I'm crossing my fingers!
Best Answer08-28-2018 09:39
08-28-2018 09:39
08-28-2018 10:08
08-28-2018 10:08
Hey there @FlyFrosty! I'm glad to hear that you were able to sync your Ionic to Pandora. ![]()
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer08-28-2018 10:52
08-28-2018 10:52
Next, learn rocket science and truly understand black hole theory.
This is pretty lame.
Best Answer08-28-2018 14:05
08-28-2018 14:05
I think you mis-interpreted my response as positive. Your "solution" is only partial and wholly unacceptable. The entire process is broken.
Thank you for the invite to the Discussion boards. I have spent a great deal of time there already. The only "solution" there is the same/similar as yours. Once again, this solution does not "fix" the problem. The "solution" may work once and then often fails again. There is an obvious problem with the app and its ability to sync as advertised...as repeatedly detailed in the Discussion boards. The solution obviously lies in fixing the app and not in re-setting the tracker and manually updating on a repeated basis.
08-28-2018 19:34
08-28-2018 19:34
Best Answer09-04-2018 18:41
09-04-2018 18:41
i hope it's not the ionic, as i have NEVER been able to get it to sync to pandora. tried multiple times a while back and again over the last days. it gets up to downloading around 25% and craps out, no music is transferred etc. It sucks. If you haven't opened the box don't. Send it back. The music downloading is just awful.
11-08-2018 16:23
11-08-2018 16:23
My husband and I both have the Ionic and neither one can sync to Pandora! Fitbit.....if you want users, FIX THE PROBLEM don’t make your Fitbit community take 25 steps to fix a problem that is not theirs to begin with! As a multi million dollar company I would think you could afford to make a product that actually works!
