09-29-2017
09:05
15:08
SantiR
09-29-2017
09:05
15:08
SantiR
I can only get the display on my Ionic to come on if I turn my wrist over and over, and eventually the display will come on. Yes, I can hit the button, but that is frustrating if I'm doing other things. It appears that either this Sensor is not working properly or it's slow.
Is anyone else having this issue?
Firmware Version: 27.25.16.7
Moderator Edit: Updated Subject for Clarity
10-03-2017 07:54
10-03-2017 07:54
Another post on here resolved the issue for me. From home screen, swipe right and make sure screen wake is set to auto. Mine was originally, then somehow reverted back to manual until i fixed it again.
09-29-2017 09:19
09-29-2017 09:19
Mine is usually pretty good, but I do notice that it needs to be a pretty fast motion and with a definitive turn of the wrist to face me.
10-02-2017 23:30
10-02-2017 23:30
Mine display used to turn on also on a flick of the wrist. It doesn't do it anymore. I rebooted my watch and still the same thing.
10-03-2017 06:34
10-03-2017 06:34
I'm having the same issue. Fitbit support through Twitter told me to restart the watch a couple of times. That did not work. Waiting for another response.
10-03-2017 07:54
10-03-2017 07:54
10-03-2017 08:36
10-03-2017 08:36
That worked. I was trying to find a menu setting for that. I didn't even know about the swipe right menu. Thanks.
Best Answer11-02-2017 21:14
11-02-2017 21:14
My display on iconic has stopped working when I shake or rotate my hand. It used to work well until a week ago. Now only way I can see the display is by pressing a button
Best Answer11-02-2017 21:17
11-02-2017 21:17
Thank you. For some reason mine also went to manual. Great help.
Best Answer11-03-2017 04:28
11-03-2017 04:28
Your post it is correct, it solved the problem!
Best Answer11-19-2017 20:29
11-19-2017 20:29
Must have reset on the last firmware update to 'Manual' and notifications 'Off'.
Best Answer11-23-2017 11:14
11-23-2017 11:14
Thank you, thankyou, thank you!! How simple - makes me feel so dumb!!! I'm just a week with the Ionic - guess I will learn!!!
Best Answer11-23-2017 12:40
11-23-2017 12:40
That did it for me. Thanks!
Best Answer11-23-2017 22:37 - edited 11-23-2017 22:43
Does anyone know if it is possible to have the watch face displayed constantly? Even when set to auto, it takes a massive, over-exaggerated turn of the wrist (like something out of a cartoon!) for mine to turn on! It would be handy if it could just have the time displayed constantly.....
11-23-2017 22:46
11-23-2017 22:46
Best Answer11-24-2017 00:54
11-24-2017 00:54
@Bootzies No, it is not possible to have the click display always on.
Helen | Western Australia
01-22-2018 19:26
01-22-2018 19:26
Thanks! This just solved my problem too!
Best Answer03-11-2018 09:56
03-11-2018 09:56
This worked perfect. Thank you!!
Best Answer04-03-2018 11:50
04-03-2018 11:50
The swipe-right is no longer available. To reach the Quickview (Screen Awake) settings you need to press and hold left button. That is also Music control.
04-03-2018 16:41
04-03-2018 16:41
I also contacted Support, and their suggestion to swipe right and select Screen Wake - Auto worked for a few days, but then it started constantly reverting back to manual, or, even more maddening, to a screen that shows all my stats, but NOT THE TIME. I'm getting very frustrated with how difficult it is to simply see what time it is!
Best Answer04-03-2018 16:45
04-03-2018 16:45
After the latest update, I could no longer see the time when I lifted my arm, so I contacted Support. The rep told me to hold the left button down a couple seconds, then swipe right and select Screen Wake - Auto. That worked for a few days, but then it started either constantly reverting back to Manual, or to a screen that shows all my stats on the right side of the screen, but NOT THE TIME. I'm getting very frustrated with how difficult it is to simply see what time it is. Does anyone know how to fix this? Thanks
