03-25-2018
06:52
07:20
03-25-2018
06:52
07:20
Since the new update.... my text won’t show up on the Fitbit, even when I have the notification for text and calls set to on. Also I used to be able to just flip my Wrist and see the time and now I have to push a button to do it and can’t find the display setting to change it help!
03-27-2018 07:14 - edited 03-27-2018 07:20
Welcome on board @Cmacnair04, hope you're doing great! Please restart your Ionic by following these steps:
Then, on Fitbit Ionic, press and hold the back button and swipe to the shortcuts screen > Screen Wake.
Also, to turn on the device's notifications settings press and hold the back button and swipe left to access the shortcuts screen. Make sure you can receive notifications from your phone. If you're still not getting notifications on your Ionic, please check this post for troubleshooting steps (if necessary go to my second post. No worries about the board it's posted, the steps I provided work perfectly with your Ionic except for the restart, but the restart steps can be found at the beginning of this post of mine).
This should bring the Quick View and notification features back. Let me know the outcome!
05-14-2018 11:55
05-14-2018 11:55
I am having the same problem. My notifications are not showing up ever since I ran the last update. I have reset both my phone and my fitbit ionic. I have checked on both my watch and my phone that notifications are indeed turned on. I had disabled and re-enabled bluetooth.
Also, I am not able to even access the wireless settings. Every time I try, I get an error and it asks if I want to retry .
None of this was happening before the update and I have not changed anything else on the phone or the fitbit.
Thank you.
05-20-2018 08:23
05-20-2018 08:23
I'm having the same issue.
05-22-2018 07:29 - edited 05-22-2018 13:04
Thanks for jumping into this thread @Hlant @Dwoell and for trying some troubleshooting steps. Nice way to go!
While reading your posts, I was wondering if you both are not getting notifications at all? If so, please check and follow the steps provided in the article My Fitbit device isn't receiving notifications from my phone.
On the other hand, if what's happening is that your notifications are being removed after opening them on your phone, please note that with the new Fitbit OS update 2.1, Notifications are now removed from the Versa/Ionic once you open the conversation in your phone. This is expected behavior and not an issue.
I hope this resolves your inquiry, if there's anything else I can do for you, please feel free to reply.
05-22-2018 08:43
05-22-2018 08:43
05-22-2018 12:56
05-22-2018 12:56
I'm having a problem, too. I can receive test notifications from the fitbit app, and last I checked I can receive notifications from the apps I have set to receive them from, but my text message notifications aren't working. I've tried every step on the troubleshooting page, and nothing has fixed the problem. My friend is having the exact same issue, other notifications work but texts do not. Would love to know what the issue is.
