09-16-2019 12:00
09-16-2019 12:00
I received a replacement Ionic under UK warranty because the old one had battery drain after only 6 months.
I am trying to set up the new Ionic but I keep getting "Update Failed" when it tries to update the firmware via wifi.
I have reset the device several times and tried with both the Android and Windows 10 apps.
The wifi and internet connections are good.
I don't really want to try via Bluetooth as that will take far too long.
Can anyone help?
Best Answer09-17-2019 07:03
09-17-2019 07:03
It's great to see you around @Neiljd. Thanks for the details mentioned and the troubleshooting tried.
I would like you to double check and perform the following once again:
Let me know how it goes.
Best Answer09-17-2019 07:05
09-17-2019 11:20
09-17-2019 11:20
Thanks for the replies.
I used Bluetooth in the end. It took a very long time.
