08-28-2017
11:40
15:55
ErickFitbit
08-28-2017
11:40
15:55
ErickFitbit
My Phone notification got me all hyped up for the new Fitbit Ionic announcement today. I always thought the charge was missing something and this new watch is exactly how I pictured it. I love my fitbits and I have been using this Screen Protector brand since the fitbit zip and until this very day, my screen looks new even if I attach it to my dog's neck collar now when we go running in the afternoon. lol! they should make one for dogs haha. I already put my order in for both my new Ionic and this shield saved all my fitbit devices. I recommend this company.
Moderator edit: removed advertising link
10-05-2017 11:53
10-05-2017 11:53
@N8teGee wrote:@shipo Were they a wet install type? I have received some Skinomi that are wet install. I'm still debating whether to use them or not at this point, they do seem a lot less tacky feeling to most wet install ones though.
Silly me, I don't know what a "wet install" is. 🙂
The screen protector I purchased comes with a film covered on both sides with a thinner film; peel the "Bottom" layer off, affix the film to the face of the Ionic (and push out the bubbles), peel the top layer off. That's all there was to it.
10-05-2017 11:59
10-05-2017 11:59
Sounds like the first ones I tried. I couldn't get them on without any bubbles.
Well a wet install is where you use a very mild detergent spray, it basically gives you time to move the protector around and remove the bubbles before it finally adheres, the same concept as a skin.
10-05-2017 12:24
10-05-2017 12:24
@N8teGee wrote:Sounds like the first ones I tried. I couldn't get them on without any bubbles.
Ahhh, well then the protector I used qualifies as a dry install. Once installed, I had to partially peel the film back a couple of times to get it down with no bubbles; I'm thinking the full installation took no more than five minutes. Having done it once, I'm thinking if/when I have to put another film on it will take me no more than a minute. 🙂
10-05-2017 12:33
10-05-2017 12:33
I use 3M paint protection film on the front of our cars, and on my bikes. I've also applied UV film to the windows on our house. You can apply it dry, but its better to apply wet as you can easily remove air bubbles and then let it dry.
10-05-2017 12:42
10-05-2017 12:42
Here's the end result with the screen protector in place:
10-05-2017 14:18
10-05-2017 14:18
Looks good @shipo. Like you say you can't tell anything is on there, well certainly not from the picture anyway. My installation was nothing like that haha. I think for now I will leave the screen naked.
10-05-2017 14:36 - edited 10-05-2017 14:39
I've used the Skinomi skins on other devices, as long as you do the install correctly it'll be fine - if you don't, you'll get blurring and / or visual abnormalities (a lens refract effect) from the film. Other brands may be hit or miss depending their film supplier. I've always had luck with them.
The only difference between a Skinomi for one device and another device is the die cut (shape). It's still the same material and adhesives.
10-09-2017 12:38
10-09-2017 12:38
I just always over protect my devices. That's me.
Wendy | CA | Moto G6 Android
10-12-2017 07:15
10-12-2017 07:15
I have bought several of these in different colors and they're great protection for the metal pieces of the Ionic and they really look good. I like them.
10-17-2017 13:34
10-17-2017 13:34
Unfortunately the "gorilla glass" isn't very strong. I have only had my ionic for 3 days, this afternoon I barely bumped my hand against my desk at work and I now have this huge scratch on my screen.
10-24-2017 03:46 - edited 10-24-2017 03:47
I have been concerned with the fact that our wearables will eventually get some scratches and dings. Like for regular watches you cannot avoid it. Protecting the screen is one thing but also the case should be protected. However, like for a mobile phone, a hardcase protector will collect dirt on the inside, ultimately scratching the surface of your wearable.
This has happened to all my phones so far.
11-23-2017 18:37
11-23-2017 18:37
Yes .... My screen has cracked !!!!!
11-23-2017 18:43
11-23-2017 18:43
What did you do? ... I have had mine several months and it cracked yesterday .... I had been in an arm sling for last three weeks, so not much activity to crack screen .... Not a happy camper here ....
11-27-2017 23:27
11-27-2017 23:27
Recommended: http://www.screenknight.com/fitbit-ionic-screen-protector-military-shield/
Super clear and easy to install without bubbles.
11-29-2017 12:32
11-29-2017 12:32
nope the glass will crack ..... FitBit design does not protect the edges of the glass .... get a scratch proof shield and/or protective case like your phone or you will crack your IONIC like I did with me arm in a sling after surgery ... go figure that one ....
01-01-2018 12:43
01-01-2018 12:43
Hi,
I've been looking for a tempered glass protection for my Fitbit Ionic for several days, but without success!
Can someone help me?
01-02-2018 00:09 - edited 01-02-2018 00:10
@Voyo33 wrote:Hi,
Due to the Ionics curved glass, I very much doubt you will ever find a Tempered Glass protector for it. I tried a couple of film types, but eventually I just decided to use it without any protection. I've had it since launch and so far so good.
01-02-2018 10:20
01-02-2018 10:20
I was told by a Fitbit rep if a screen protector was used it would void my warranty.
01-02-2018 10:54
01-02-2018 10:54
@bugsy01 wrote:I was told by a Fitbit rep if a screen protector was used it would void my warranty.
Yeah, right, lol !
Let's leave the absurdity of the claim aside... but do you think that they will ever know that you had one if you peal it off before sending the watch in for repairs?
01-02-2018 11:20
01-02-2018 11:20
@Voyo33 wrote:Hi,
Go to the Nillkin website, and send them a message, anyone who thinks we should have a good, glass protector. If they get enough momentum, they'll produce one, I've seen it happen for "smaller volume" devices, I think they're "layup overhead" is pretty small, and they've always responded, with a personal message, when I ping them.
I have a "watch" on their site, for the Ionic, and if they make one (I already pinged them), I'll be ready to purchase, I prefer a glass protector, far-and-above, nothing beats the smoothness and durability.
Nillkin works because it's thinner than most (0.26, see my other post), but curved glass is do-able too, like my OnePlus 5T, it has a good glass protector that's curved/beveled, and has been on for a couple of months.
I've a Nillkin go almost a year, without peeling, on a curved phone...
