11-02-2017 11:20
11-02-2017 11:20
I have had my fitbit for about 3 weeks now but today it decided not to light up my screen when I turn my wrist could a setting possibly be turned off? .... it is also inconsistent with syncing up to let me know about text and calls I love this watch and will be heartbroken if I have to get rid of it!!
Best Answer11-02-2017 11:27
11-02-2017 11:27
Nevermind I figured it out it was just a setting issue!
11-02-2017 11:27
Best Answer11-04-2017 20:51
11-04-2017 20:51
Can you tell me what setting it is under? Mine is doing the same thing and I can't figure out how to fix it. Thank you.
11-04-2017 22:56 - edited 11-04-2017 22:56
Swipe to the right on the Ionic and check whether your 'Screen Wake' is set to manual or auto.
If it's set to Manual then you have to press the button to wake the screen.
If set to Auto then the screen will wake when you raise/flick your wrist
11-20-2017 00:04
11-20-2017 00:04
Thanks!!
Best Answer06-12-2018 22:38
06-12-2018 22:38
Thank you! Finally decided to look it up after 2 weeks like this . thanks!!!
