10-12-2017 20:20
10-12-2017 20:20
The font when I have to set "cue every" for my running activity is too large and I'm able to see only the digit after the decimal point. I'm using "km" as measure unit.
Best Answer11-13-2017 07:13 - edited 11-13-2017 07:25
@dash1e Welcome to the Fitbit family! That is very strange! Just checked on mine and it is showing correctly on both miles and kilometers. Are you still experiencing this?
If you are, check if there are any firmware updates for your watch. If you have any update pending, please update and check if the cue option will show like that again.
You can also try turning off your watch, waiting a moment, and then turning it back on.
If after doing this, it still shows like that, please share a screen shot here so I can take a look at it and further help you out!
Keep me posted! ![]()
11-14-2017 12:25
11-14-2017 12:25
The last update (I appied it this morning) has solved the issue!
11-15-2017 06:22 - edited 11-15-2017 06:25
@dash1e Thanks for your reply! I'm very glad to hear that you are not experiencing this anymore. Thanks for sharing with the Community that the solution helped you out with this. I'm sure this will help other users as well for sure!
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around! ![]()
