10-20-2019 10:35
10-20-2019 10:35
My app wont set the bed and awake times. I can set the time but there is no OKAY button for it to register. There is only remove and cancel. They were set and after I went to change them they would not set again. Anyone else have this issue?
Best Answer10-20-2019 10:51
10-20-2019 10:51
Hi @GRS22 welcome to the forums. Can you be a bit more specific about your issue if possible. What do you mean by bed and awake times? Are you trying to log some sleep or set an alarm?
Best Answer10-20-2019 11:04
10-20-2019 11:04
Best Answer10-20-2019 11:25
10-20-2019 11:25
Oh ok, so on the sleep goals page you're trying to change the times. Can you post a screenshot if possible? I've checked mine and when I go to adjust the time there is a save option on the bottom right.
Best Answer10-20-2019 11:27
10-20-2019 11:27
Best Answer10-20-2019 11:35
10-20-2019 11:35
Hi, nothing showed up. Could you try again? This is what I see
Best Answer10-20-2019 11:39
10-20-2019 11:39
Best Answer10-20-2019 11:40
10-20-2019 11:40
Mine os the same except no OK button...
Best Answer10-20-2019 11:54
10-20-2019 11:54
Hi Grant, are you using the camera icon on the message toolbar?
Best Answer10-20-2019 11:57
10-20-2019 11:57
Best Answer10-20-2019 11:59
10-20-2019 11:59
No worries, glad it's sorted.
