04-28-2018
12:51
04:07
AlvaroFitbit
04-28-2018
12:51
04:07
AlvaroFitbit
Hi
I am OS2 and somehow managed to get the battery level to display permanently on the top left hand corner ( really liked thjs ). However it’s disappeared now and I need to do the annoying thing of swiping up every time to see battery level.
Any idea how to make battery level display permanently in the top left hand corner of the screen ?
13:20
04:08
AlvaroFitbit
04-28-2018
13:20
04:08
AlvaroFitbit
Lots of clock faces display the battery level on the clock screen. For example, the one that I use called ASK displays the battery Icon with graphic level and touching the Icon also brings up the battery percentage.
A warm welcome to the Community @Haz11! Just as @SunsetRunner mentioned, there are many third-party clock faces on the app that have the battery percentage on the screen. To mention just three, you can check duality, simple corners and circled clock faces at the bottom of the page.
Regarding the third-party clock faces, they might change from time to time as these are developed by other users and not Fitbit.
Hope this helps! ![]()
