I have a problem with my silent alarms. When I have to enter my pincode (which I have to do every 24 hours) my silent alarm won't go off. Meaning that when it's more than 24 hours ago that I entered my pin, my alarm won't go off.
Since I usually take my Ionic from the charger during the night (when I wake up to go to the toilet) I have to enter my pincode then. Because of this the next night I have to enter my code at the same time (which I don't do because I'm sleeping then). And this causes my alarm not to go off, which is really annoying because I oversleep.
Any solutions?
Best AnswerHi @Hugor83
I think changing your PIN Code setting may help.
WHEN DO I ENTER THE PIN CODE TO UNLOCK MY FITBIT DEVICE?
You must enter your PIN code at least once a day. Your Fitbit device prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment.
To change the device lock setting:
> your profile picture > your device image.
I have my PIN Enabled for Fitbit Pay. It only asks me for my PIN when I am using Fitbit Pay. Otherwise, I don't have to enter it.
