10-05-2017 01:09
10-05-2017 01:09
Hi Guys,
Has anyone had any issues with the sports band? I was teaching a dance class yesterday and the ionic came away from the band. Luckily I had a long sleeved top on and was caught in the sleeve so was saved from the floor. Further inspection I have noticed that one side of the band doesn't fully clip in . You don't get that nice satisfying "click" ... Unfortunately the additional band was a gift and I chucked all the packaging away. I want to get a new one but wanted to check if anyone else was having similar issues before purchasing.
Thanks
Rachel
10-05-2017 04:15
10-05-2017 04:15
@Rig I recommend trying to push it in again but as hard as you physically can, try not to put pressure on the screen though. I noticed I had to use alot of force when I tried to reattach my band.
If that still doesn't work then reach out to fitbit support. I'm assuming the sports band was an official fitbit one? It doesn't matter that you haven't got the packaging, they should still sort it out for you.
10-05-2017 02:15
10-05-2017 02:15
Hi
Feel free to contact the fitbit support team, mention it's been a gift (it's up to them to decide).
10-05-2017 03:26
10-05-2017 03:26
My sports band turned up this morning. Had to push pretty hard but there was a definite click on mine. Maybe yours is faulty?
10-05-2017 04:15
10-05-2017 04:15
10-05-2017 05:42
10-05-2017 05:42
Thanks all! I pushed a bit harder and I got the click 🙂
It is an official sports band...
Will have to watch that in future that could have been the first smashed one 😮
10-05-2017 05:52
10-05-2017 05:52
The click is very important, when switched to smaller bands (first attempts).. didn't hear the click, though pulling gently to test fitted secure, the band parts came loose..
Happy Fitbitting
10-05-2017 06:13
10-05-2017 06:13
Glad you got it sorted @Rig
10-05-2017 20:07
10-05-2017 20:07
Glad you got it to snap. I've had the same problem with one of my straps that came with the fitbit.
BTW, is the sports band fit more comfortably? The default band is really uncomfortable.
10-05-2017 22:05
10-05-2017 22:05
@Rig glad you got it to click and that it wasn’t faulty 🙂
@Fit2030 in my opinion the sports band is so much more comfortable than the classic band that came with the Ionic. It is very flexible and moulds to my wrist. I bought the charcoal/smoke grey Ionic but really wasn’t keen on the light grey strap but he black sports band looks amazing!
10-06-2017 03:00
10-06-2017 03:00
I'm using the default strap that came with the box and I'm having the same problem. I was hoping to paddle with this watch but now I don't think I should. 😞
06-08-2018 08:56
06-08-2018 08:56
Yes. You were lucky I wasn't. While cycling, the band came out, dropped on the road and the screen cracked. My top strap was faulty from where it severed. Just two weeks old, under warranty. Customer care is attributing it to mishandling and refusing to replace. Am still in touch. With God's grace n your support, hope they understand the frustration of user having spent so much money n without any fault, the beautiful Ionic is damaged.
