Hey guys
ive had no issues until now with using my Fitbit to record runs and the data transferring to Strava but today no luck 😞
ive checked and in my iPhone app it’s says that Strava isn’t authorised yet if I log in through a browser to my Fitbit account it says it is?!
Ive tried restarting my Fitbit ionic, logging in and out of the app and my account on both Fitbit and Strava and reconnecting and still no luck
Any other suggestions?
I looked through the other posts but couldn’t see any resolutions to the same issues...
Thanks so much!
Yes, it is linked in both my account online and my Strava account online and the app
but the Fitbit app says “not authorised”
ive fried factory reset on my Fitbit, uninstalled the app, revoked access to Strava and vice versa
And still get this coming up in the app and it won’t sync my runs
It was working fine a week ago.. not sure if there was an update to the app or watch that has changed something??
The factory reset is between your tracker and your Fitbit account. This will not affect the link between your Fitbit account and your Strava account.
May I ask which app is your screen shot of?
@Coffeelover wrote:Yes, it is linked in both my account online and my Strava account online and the app
You mention three accounts here.
Your account online. Which online account.
Strava account and Strava app these are the same thing
I'm still not sure which app is not able to link up with Strave.
Your Fitbit Account or the Strava app on the Versa.
I use the iPhone Fitbit app 🙂
Best AnswerSorry for the confusion
my iPhone Fitbit app won’t authorise my Strava account
Best AnswerBut is it your iPhone Fitbit app that is not linking up with Strava?
Does Strava show as linked in you Fitbit settings?
Yes just my iPhone app that is not linking with my strava account
it says in the Fitbit settings that it is connected
but it the app shows that “not authorised” message
and if I log a run through my ionic, sync it with the iPhone app, it doesn’t transfer to strava
Your Fitbit app does not connect to Strava. You are looking at the setup for the Strava app on your Ionic.
Just like the Strava app on your phone you will need to press login and log into your Strava account. This app has nothing to do with the Fitbit/Strava link.
Yes I’ve done that many times,
- clicked “authorize”(on the iPhone Fitbit app) been redirected to log into my Strava account,
- logged into my Strava account and then been redirected back to the iPhone Fitbit app and it still says “not authorised” and account says N/A
(whereas it used to have my Strava account details but it now won’t change to that)
even though I it says Fitbit/Strava is linked/connected in the Strava iPhone app, through my Strava account online on a pc and on my Fitbit account on a pc
and when I record a run it doesn’t transfer to my Strava account
And I have an android phone. So it's not just an iPhone issue if that helps
Best Answer@Coffeelover as mentioned above, this has nothing to do with the fitbit/strava link
Your setting up the Strava App that is installed on the Versa. The problem is that this app is having problems logging into the users Strava Account.
Since this Strava app is written by Strava and is having problems logging in, I suggest tapping the contact developer link and bring this to the attention of Strava.
They are the ones that need to address this issue..
Best AnswerI’ve tried clicking this link and it takes me to a Fitbit troubleshooting page
is there anywhere we can escalate this too?
Non of my runs are transferring to strava it’s very frustrating
A warm welcome to the Community @Coffeelover and @Liberty728. I appreciate the details that you've mentioned as well for the troubleshooting that you've tried.
This issue has been escalated as you can see on this other thread. I would like you to subscribe yourself to it and as soon as there are more updates, it will be posted there.
Thanks for your support @Rich_Laue.
Your patience and understanding is appreciated.
