Hi there,
I think my Ionic is broken. Yesterday I put it on the charger like every two oder three days. After full charge everything still seemed okay -- until a notification on the phone told me, that the battery of the Ionic was empty.
What? It was 100% charged just three hours ago.
Okay, back to the charger.
With a -- again -- fully charged Ionic I was able to see the dilemma: You can watch the battery gauge going down, one percent by another. Strange...
I switched off bluetooth at my mobile just to be sure, that the problem has something to do with nonstop syncing -- but not change. The battery drain continues even then.
Next step: Restart. No change.
Next: Factory reset and reinstallation.
Again no change. After configuring everything the continuous battery drain remains.
And there is another new stange behaviour: My Ionic now reacts delayed. When I turn my wrist to trigger the automatic display nothing happens anymore -- or with a delay of two three seconds.
Has anyone else has seen this?
I already contacted Amazon to swap it.
