I've recently bought an Ionic and use it to track my runs.
However I can't get my live stats to show on my watch when I start the run tracking from the fitbit app on my phone. I want to be able to hear the audio cues every km but quickly check progress on my wrist.
I know l you can start tracking directly from the watch and get all the live stats that way but when i do this it means I won't get the audio cues.
Is it possible to have both sync up simultaneously? So I have audio cues and map tracking on my phone live with my current run stars on my watch.
Thanks in advance.
A warm welcome to the Community @Hesooo! You can get run cues in your Fitbit Ionic but it will work with the exercises that you can track directly from the tracker itself. When you're using MobileRun, it will take the ones from the application. You can learn more about it by checking this article How do I use exercise apps and modes on my Fitbit device?.
Currently, it's not possible to merge both stats. However, the exercises that you have in the app, you can track them as well in Ionic using the tracker cues.
Hope this helps!
