08-30-2020 00:39
08-30-2020 00:39
Morning all
How do i sync my fitbit using my PC ?
Thanks Adam
08-30-2020 01:38
08-30-2020 01:38
If your PC is running Windows 10 and has a recent version of Bluetooth then you should be able to install the Fitbit app from Microsoft Store. Once signed on it will sync when you open the app or you can manually sync from within the app.
