09-08-2018 06:06
09-08-2018 06:06
My Fitbit and ionic constantly do no sync. I have uninstalled and reinstalled device. I will reconnect to wifi. It will work then it won't. It has been not working a lot lately and my ionic is only a month old. I'm getting really frustrated.
09-08-2018 07:24
09-08-2018 07:24
Go to the bluetooth of your cellphone and remove the bond of the ionic. Then try to sync again directly from the fitbit app. Usually this works for me when having syncing issues.
Best Answer09-08-2018 12:14
09-08-2018 12:14
Thank you so much for the help!!! So I don't want it connected through Bluetooth at all?
Best Answer09-08-2018 18:56
09-08-2018 18:56
Mine is the same and I can't figure it out. I've had it for 5 months and it is annoying. Even with Deezer it took so many goes. Now my fitbit whenever I charge it has the fit bit icon showing and I cant chage it I have to wait till it runs out of battery.
Best Answer09-16-2018 05:55
09-16-2018 05:55
This worked the one time and now it's back to not syncing. I feel like the issue might be the Bluetooth in the ionic.
