Not really happy after 6 months of running like clockwork the clock is not displaying the right time. And hour after syncing the clock is showing 6 mins behind the right time and the gap getting bigger anyone else have had that problem?
@Doreyo wrote:Not really happy after 6 months of running like clockwork the clock is not displaying the right time. And hour after syncing the clock is showing 6 mins behind the right time and the gap getting bigger anyone else have had that problem?
Yes! Generic answer on the forum is to check your time settings in the app and on your phone. Sync another time zone to the device, then sync the correct time zone to the device after. Restarts etc...
Nothing worked for me as it still kept reverting to a different time, along with all the other problems. Wasn't the phone or the app settings that were incorrect as it synced the time correctly with other devices
Best AnswerI had it for 6 months no issues. I sync it at 12;00 at 13:00 it shows 12:56 on my fitbit. At 14:00 13:52. It starts at the correct time but can't hold it. Before Thursday everything was fine.
@Doreyo wrote:I had it for 6 months no issues. I sync it at 12;00 at 13:00 it shows 12:56 on my fitbit. At 14:00 13:52. It starts at the correct time but can't hold it. Before Thursday everything was fine.
I had 2 Adidas Editions. Neither had an issue with syncing time for the first few weeks of use, or any other faults. Then after about 3 weeks they both started acting up, but only one had an issue with time. It became completely unusable. Never did get to the bottom of the time issue as I tried everything that was suggested to rectify it, and it was the last straw in the long list of bugs on both devices so I returned them both
Best AnswerI have the same issuse since few days. At the same time my Ionic is not able to sync wit my Iphone 7 (after restarting the watch it synks one and thats it...).
Did you find a solution?
Best AnswerHi mate.
I did a full reset on it really installed fitbit app. Still had the same problem. Ended up talking to fitbit on twitter and ended up getting a replacement unit.
