What is the most ideal exercise app on the Fitbit Ionic to track cross training? Is there one app that will GPS track a run, track lifting weights, and GPS track a run again all as one workout?
I performed a workout like this but had to switch between the "Run" app, then over to the "Weights" app, then back to the "Run" app. It got the job done but I could not see a cumulative total time of the workout, the Ionic treated it as three separate workouts.
Best AnswerHi @Ahyrk, nice to see you in the community.
The simple answer is no as far as I understand. I think the best and only solution is the one you are currently doing. I believe logging the workout with the 3 different exercise option would likely be more accurate anyway vs one mode trying to track and workout your calorie burn for 3 quite different activities.
