05-01-2019
04:08
12:01
SilviaFitbit
05-01-2019
04:08
12:01
SilviaFitbit
Hi, Ive had the fitbit ionic for a few days and been trying to get it to work as expected.
So far I can track my workouts and these are fed to the strava app on my iphone but, and this is the issue, the strava app on my ionic does not display any data and simply says " NO RECENT ACTIVITY"
ive had a webchat with fitbit who say this is a known issue, but they cant give me any timeframe for having it resolved.
SO my question is.... has anyone actually got the map and data displayed on the Ionic strava app?
If so, please let me know how is it?
Best Answer05-02-2019 12:00
05-02-2019 12:00
It's great to see you around @JamesUKrunner. Thanks for letting the forums know that you've contacted our Support team.
As mentioned by them, we’re aware of it and working to identify a resolution as quickly as possible. we're sorry for any trouble and we appreciate your patience and look forward to getting you back on track.
Hope another user can jump in and share its experience with Ionic and Strava.
Best Answer05-03-2019 06:08
05-03-2019 06:08
Any update on this issue?
What is the timeframe for having it working?
Is it Hours, Days, Weeks, Months?
When was this problem first noticed and reported and when was the last time it was working?
Nobody has said they have had it working
Some more info would be good rather than glad handing please.
Thank you
Best Answer05-07-2019 08:40
05-07-2019 08:40
Mine stopped syncing around May 4th. Good to hear that it's being worked on. So far now I'm uploading by sending a downloaded file from Fitbit to strava. I think it's called a tcx file.
Best Answer05-07-2019 12:30
05-07-2019 12:30
I started having trouble may 3rd; I also get on my laptop and download to tcx file and then upload to Strava. Glad to hear I’m not the only one having issues. Hope it’s resolved soon!
Best Answer05-07-2019 17:08
05-07-2019 17:08
Thanks for participating in the forums @JamesUKrunner. I would like you to check the main thread here and follow the tips mentioned by another Moderator.
Great to see you around @TerriF1970 and @Trichrun. Thanks for the details that you've mentioned. I also appreciate the workaround that you've tried. If your accounts aren't syncing, please try the procedure mentioned in this article by Strava.
If you're having trouble connecting Ionic and Strava, you can check the main thread and follow the tips mentioned by one of our Moderators.
Keep me posted.
05-08-2019 06:36
05-08-2019 06:36
So last night I tried more time of revoking access,deleting strava from my ionic and then started over.. I had did this before. So far I had a walk from 3 days ago sync. I'll see how it goes this morning after my run. 🤞
Best Answer05-20-2019 04:42
05-20-2019 04:42
Any update on this issue being fixed?
Could a timeframe now be put on this to be resolved and at which point then if it isn't then Fitbit could offer a full refund on the ionic as it is effectively mis-sold?
Best Answer05-20-2019 05:41
05-20-2019 05:41
Mine started working again about May 8th. I had tried doing all the suggestions from the app but what seemed to work was doing it from the fitbit.com and strava.com side of things. It could have been a coincidence but I haven't had any problems since.
Best Answer05-20-2019 07:25
05-20-2019 07:25
doesn't work for me
Best Answer05-20-2019 07:28
05-20-2019 07:28
I would contact Fitbit direct then.
Best Answer05-20-2019 07:31
05-20-2019 07:31
That's what this forum is for!! its a known issue, apparently Fitbit is working hard to resolve it.
Any update on this fitbit?
Best Answer05-20-2019 12:57
05-20-2019 12:57
Mine hasn’t crossed over to the actual Strava app on my watch for a while. Personally I never really look at it on my watch but it isn’t working correctly.
05-20-2019 13:15
05-20-2019 13:15
I rarely look at the runs on my watch either. Ive no problems with syncing now for over a week.
Best Answer05-31-2019 04:00
05-31-2019 04:00
not holding my breath......
Any update fitbit ?
