04-28-2018
15:52
08:57
MaginB
04-28-2018
15:52
08:57
MaginB
Is there a way to turn off distance for workouts that don't need it ie. weightlifting. It's not GPS but I don't need to know I went 250 m while lifting. Thanks
Best Answer05-01-2018 08:56
05-01-2018 08:56
Welcome to the Forums @Fitjo6!
Thanks for sharing your inquiry, let me help you out. The summary of stats that you get at the end of the exercise when you're logging Weights using your Ionic are:
Please confirm if you're using the Ionic and the activity mode specifically with the "weights workout". I also recommend checking this great article.
Keep me posted!
Best Answer05-01-2018 11:07
05-01-2018 11:07
I think this is the same as below. Any update on this, @MaginB?
https://community.fitbit.com/t5/Ionic/Weight-workout-is-logging-distance/td-p/2355333/
