01-08-2018 14:20
01-08-2018 14:20
I do not own a computer does this mean I definately cant complete synching ? No music, No phone calls.
Best Answer01-08-2018 20:16
01-08-2018 20:16
You will still need a computer to load music to it. You can't do that from the phone.
Best Answer01-08-2018 14:53
01-08-2018 14:53
@efc-66, if you don't have either a computer (Windows 10, Mac), or a compatible smartphone, you will not be able to sync your tracker to either of them. If you don't have a computer (Windows 10, Mac), you cannot download music to the Ionic. If you do not have a compatible smartphone, you will not have a device to send notifications to the Ionic.
Best Answer01-08-2018 15:07
01-08-2018 15:07
Best Answer01-08-2018 18:52
01-08-2018 18:52
Unfortunately there are no Nokias on the Supported Devices List so it probably wont work (but I dont know - I have never tried it)
Helen | Western Australia
Best Answer01-08-2018 20:12
01-08-2018 20:12
I believe the Nokia 8 is an Android phone. Go to the play store and download the Fitbit app. From there you can setup and sync your device.
01-08-2018 20:16
01-08-2018 20:16
Best Answer01-09-2018 00:31
01-09-2018 00:31
The supported device list seems to be out of date. My LG G6 isn't on the list but it works just fine, syncing and notifications.
03-02-2018 20:11
03-02-2018 20:11
I now have a computer but not being PC savyy don't know how to download music onto my Ionic
