02-09-2019
19:46
10:26
SantiR
02-09-2019
19:46
10:26
SantiR
Going on holidays to USA, thinking of buying an fitbit ionic but need to be sure will it work in Ireland when I get home?
Moderator Edit: Format
Best Answer02-10-2019 05:57
02-10-2019 05:57
Works anywhere in the world.
Best Answer02-10-2019 07:03
02-10-2019 07:03
@Markoscar Ireland should be no problem, I'm in competition with several from Ireland every week
Techically @SunsetRunner is correct that the tracker will work everywhere. However some countries have a nation wide block on the internet or limit the access, with these countries the tracker may not be able to sync. North Korea is one example
Best Answer02-10-2019 07:35
02-10-2019 07:35
Best Answer02-10-2019 10:23
02-10-2019 10:23
@Markoscar Welcome to the Fitbit forums! Thanks for your interest in buying a Fitbit Ionic on your trip to the USA!
Yes, just as @Rich_Laue and @SunsetRunner said, it will work on Ireland. However, there are some apps that will work just on some countries. Pandora, for example, will work only in the US. Yelp works in selected cities (check the cities here). Most of the apps will work with no problem so I'd recommend getting the Ionic!
Keep me posted! ![]()
