I did the latest update on my Ionic and now none of my messages will sync to it. I have tried turning everything off and restarting and still nothing. I can still receive my phone calls to my watch and I can cancel it and answer it but that's all. Please help!!!
@Baily13 Try pressing and holding the left button then swipe from right to left on your Ionic's screen and make sure notifications are set to on.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
@Baily13 If you tried my suggestion and it did not work then I would suggest contacting customer support and they will sort it for you
Hope the link below helps
Tony | UK
