10-16-2017 08:49
10-16-2017 08:49
measure the fitbit ionic also your oxygen?? it was promissed by the ionoc but i dont find it anywhere?
Best Answer10-16-2017 08:51
10-16-2017 08:51
Not available yet
Best Answer10-16-2017 10:35
10-01-2018 17:25
10-01-2018 17:25
Out i curiosity where do you find the option for VO2 Max. I have a Ionic and I can't locate it anywhere in the app or the watch?
Best Answer10-01-2018 21:01
10-01-2018 21:01
The oxygen sensor will be used in a future update to monitor sleep. Currently, the Fitbit does estimate your VO2 Max, it is just labeled as "Cardio Fitness Score." You can find it under the Heart Rate tile on the Fitbit App.
