Volume control buttons not working
I can’t control the volume with the buttons or touchscreen.
I tried 3 bluethooth devices and I always have the same problem.
Who has this problem or knows how to solve it?
2 REPLIES 2
Normally the buttons and touchscreen do control the volume so something is def wacky.  Maybe try restarting a few times - shutting down - changing clock faces.  But would not do a reset to factory unless feeling lucky.  Some have reported that has bricked their device.  Failing that would contact Tech Support and see if they can get it to work properly.  If not they should replace it right away.
Vote if this helps you at all and Vote if this is a solution to your issue [Current Leader in Ionic Forum with 15 Solutions + Thumbs Up 92]
Really there is no need to suffer in Frustration - simply call Tech Support at 877-623-4997 and get your Ionic replaced right now while you can
Many have followed this straightforward advice and now have a replacement Ionic - we all should have “zero tolerance” for any defective Ionic
I triedit all.
the support team said the same things. Replacement is not an option they say.
