05-14-2018 21:51
05-14-2018 21:51
I had my wallet on my ionic fit bit, how do I unhide it?
Best Answer05-14-2018 22:44
05-14-2018 22:44
Sounds like you might have uninstalled it. Try going on to the fitbit app on your phone, then tap the little square card icon in the top right corner (that will bring you to your account page), under devices tap on Ionic, then tap on apps, and then all apps, use the search icon in the top right corner and search for wallet, tap on the wallet search result and finally tap install. Hopefully you will now have the wallet back on you Ionic.
