Water consumption
ANSWERED
Normally I can see my water consumption which I added in the Android App. But Now Mo value is shown in the Overview.any advice?
1 BEST ANSWER
Accepted Solutions
@myrinhAre you referring to the Water Bottle icon shown on the Dashboard or the Drink Counter Ionic app? The latter has no connection with the former and anything you input in it won't be reflected in your Dashboard.
6 REPLIES 6
I'm referring to this part of the Android App
@myrinh Are you able to Log Water, using the “+” icon on the dashboard? (Though I note your picture does not include it)
I tap on the menu of the path with the water and then I can add the amount of water which I have drunken but they won't show up in the overview.. but they did before
@myrinh That sounds odd. If you can add water to your log in one screen it should reflect in the other. Have you checked your dashboard on the web rather than the mobile app? Does it show there?
I can add water to the app on my phone and it shows on the watch. But if I add water to the watch it does not show in the app on my phone.
