07-01-2018
14:28
12:07
07-01-2018
14:28
12:07
For no reason (that I can see) my ionic will spontaneously lock, causing me to miss my hourly step reminders. How do I keep it from doing this?
Best Answer07-02-2018 12:10
07-02-2018 12:10
Welcome to the Fitbit Community @Gwynny! If you set up Fitbit Pay to make contactless payments from your watch, the device lock is turned on automatically and you’re prompted to set a code. If you choose not to use Fitbit Pay, the PIN code is optional.
For more information on how to use Fitbit Pay, see What should I know about Fitbit Pay?
You must enter your PIN code at least once a day. Your watch prompts you to enter your PIN code based on your device lock setting:
Note that your card issuer may require you to re-enter your PIN code to authorize a payment.
To change the device lock setting:
Hope this clarifies your inquiry, I'll be around if you need further assistance!
07-04-2018 07:07
07-04-2018 07:07
The password may be setup to lock all the watch, but the time, or just lock just Fitbit pay .
In either case the pin code needs to be put in once every 24 hours and after the watch has been removed from the arm .I've noticed that, way more than I expect .the watch thinks it has been removed from the arm, when it has not been .This is why your being asked to enter the pin.
