I am able to connect to my home WiFi but it doesn’t seem to stay connected. I only notice when I try to check weather - not sure what else needs WiFi aside from music downloads. Is there something I need to do to have it connect automatically when I’m home?
@Fitsuzq100 Your Ionic only needs the WiFi connection when doing updates or transferring music. As such there won’t be a persistent connection, so nothing to worry about.
@SunsetRunnerwrote:@Fitsuzq100 Your Ionic only needs the WiFi connection when doing updates or transferring music. As such there won’t be a persistent connection, so nothing to worry about.
/but it needs to be persistent tio download my music properly because it isn't the files are always missing and so they don't play this is very annoying
Best AnswerTrue but you didn't say you were having problems downloading music (or any other problem)
Best AnswerOf course I'm having problems down loading music because the Wi-Fi will not stay connected I don't understand because it stayed on for more then an hour to down load the newest firmware update so once it starts to down load a music file why does it not stay on
