10-23-2017 14:16
10-23-2017 14:16
Is the Ionic able to use other wireless headphones or only the ones produced by Fit Bit?
Best Answer10-23-2017 14:23
10-23-2017 14:23
Yes you can use others
Best Answer12-21-2017 13:45 - edited 12-21-2017 13:45
I spoke to Best Buy employees and was told any BT would pair. They instructed me to purchase JBLs. They do not work with the ionic. Now I have music I can’t listen to and used headphones I can take back. Customer support for FitBit said some don’t work. No answer for which ones do other than their brand.
Best Answer12-21-2017 17:39
12-21-2017 17:39
I am sorry to hear about that- I also thought any BT head phones would work. I am also pretty sure Best Buy takes back anything with a receipt. They are pretty good with that type of customer service...
Elena | Pennsylvania
12-21-2017 21:03 - edited 12-21-2017 21:04
@AW1014 wrote:I spoke to Best Buy employees and was told any BT would pair. They instructed me to purchase JBLs. They do not work with the ionic. Now I have music I can’t listen to and used headphones I can take back. Customer support for FitBit said some don’t work. No answer for which ones do other than their brand.
I have a pair of JBL sport earphones and they pair fine. What kind do you have? As long as they're not rated "Bluetooth Smart", any BT ear/headphones should pair.
