03-31-2020 10:34
03-31-2020 10:34
My ionic has shut down and won’t charge. Contacts are clean, socket is working to charge other devices but ionic is completely dead and won’t accept charge
Best Answer04-01-2020 00:35
04-01-2020 00:35
Have a look at Fitbit's troubleshooting guide for charging issues at Help article: Why isn't my Fitbit device's battery charging?
If those tips don't work then, as it says at the end of the guide, it's probably best to contact customer support.
Best Answer04-01-2020 02:15
04-01-2020 02:15
Hi @VJKal, i had the same problem as you. I think the water might have seeped into your watch. though it is waterproof but it is not 100% waterproof
for my experiences, it was out of sudden degrade in the batter lifespan and the screen will just turn on and off as if i had pressed the button. Also, the screen doesn't turn on/off when i pressed the button..
so for the above experiences, i think it was water seeping into the device.
You should raise a fault call to Fitbit live chat and see what they can do for you.
Best Answer04-01-2020 18:45
04-01-2020 18:45
Mine is exactly the same. Working fine, got notification I needed to charge. Looked at watch and not on, won’t turn on. Connected to charger and won’t charge
Best Answer04-02-2020 00:19
04-02-2020 00:19
@SARAVT if the troubleshooting guide mentioned above isn't helping then it's best to contact customer support.
Best Answer04-02-2020 02:30
04-02-2020 02:30
Iconic was low on battery and a few hours totally blank. I plugged in got 0% on screen and left charging overnight. I get no response on device this morning.
Best Answer04-02-2020 02:43
04-02-2020 02:43
@nike68 if the troubleshooting guide mentioned above isn't helping then it's best to contact customer support.
