07-16-2018 06:48
07-16-2018 06:48
Bluetoth data transfer just stopped working after perfectly so the first few days... and now just cant get it back. Tried all the posted remedies so my new FitBit near useless. I read many have this problem.
 Best Answer07-17-2018 10:10
                              07-17-2018 10:10
Hello @PaulRen I believe you might be refferringrto the syncing of your ionic data to the Fitbit server.
Without knowing what type of device that is used to sync the data, I'm unable to give much help .however I have noticed many triPs posted on these boards can cause more problems .
Why won't my Fitbit device sync?
 Best Answer07-17-2018 20:49
07-17-2018 20:49
Thanks allot Rich. I am using Huawei Pro 10 mobile, as superb phone. It all worked fine for 7 days, then just stopped synchronizing without me changing anything! I then uninstalled the FitBit app, and re-installed it, I rebooted the phone of course, made sure its updated on software...still no go. I then used my tablet (also a Huawei) and it worked fine all day, then the next day stopped synchronizing as well. Maybe the problem is Huawei is not just working with Fitbit? (The US seems to have an issue with Huawei, even while over 100 countries use it) to us its more like US does not want super Chinese competition...I live in Phuket Thailand. , I will next try my ASUS phone. Could it be FitBit does not work on the devices I use? But why did it work so well for a while only to stop?? Thanks immensively for any insight you can give me, as is now I wasted my money and time on FitBit. Cheers, Paul,
 Best Answer07-17-2018 21:43
07-17-2018 21:43
I was about to change to a recent version of ASUS top mobile, but at the last minute decided to restart the Swatch and give Huawei mobile another chance. This as of 3 hours later has synchronized well, but will it continue? Is it just an issue on restarting the Swatch ever so often? I wonder if Huwaei Pro 10 has an issue with FITBIT Ionic, or not?
 Best Answer07-17-2018 21:54
                              07-17-2018 21:54
Please remember that when syncing through the phone, if the tablet is nearby.the tablets Bluetooth needs to be off. And the opposite with yhetphone. if your syncing through the tablet.
