answer calls?
how do I answer a call on my Ionic? it vibrates. says to press lower right button but nothing happens when I do
5 REPLIES 5
Hi @Catherinepratt1. The Ionic is just letting you know that a call is coming in on your phone. It is notifying you. To answer the call, you must pull out your phone and answer it there. The Ionic does not have cellular capability.
ImI'able to accept the callcand yes the phone does answer, but as @SunsetRunner states the phone call still goes through the phone.
I also can reject or send a quick text reply .
Since the Ionic isn't equipped with a phone, the call can only be answered on your phone.  All the watch can do is notify you that you have a call.
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
You have the option to either accept or reject call on phone call notification. If you're using a bluetooth headset, answering on the actual phone would not be neccessary.
Ionic, retired Blaze.
And if i reject from my wrist i can also send a quick reply from the wrist.
