The clock faces seem to give you your steps on it. I usually use miles as my main setting. Can you change this in the clock faces? I know you can move it to the top of the fitbit today app but would like it on the main screen.
Best AnswerI have only tried one clock face, but perhaps I can add to the discussion:
I use the "Moment" face, which has the time in red on a black background, with the day, month, and date, then the heart rate and the steps displays. I'm not sure if all or any of the other clock faces work the same way, but the steps are not the only data that shows there -- by tapping on the watch face, it cycles through the other data -- calories, distance, floors, and so on.
I wasn't too thrilled with the red time color, but I was able to change the colors to white text on a blue background -- wonderful. I'm very happy with this face, which is why I haven't bothered to try any of the others. But I'm hoping that other faces cycle through the different data points, like this one does.
This is one thing that has bugged me as it is not working. Many watch faces allow you to change the color schematic, but also the stats that are showed. I have tried to change that on many designs and it just does not work. I don't care about calories or distance and have tried to remove them, but it has yet to work on any watch face.
I try this now, but it said it would only function properly when internet was ON, but I can't access internet when out, therefore I did not turn that on - will it not function then?
