Hi there I got my new phone last week.
Everethung was working fine the last few days. Then my app was saying that I have to turn on Bluetooth to sync.
Even if my Bluetooth was on and connected to Ionic.
So I turned off Bluetooth and turned it on again but nothing changed.
I taped on forget this device and since then my phone will not find my ionic any more.
Hey there @CyrilT, it's nice to see you around the forums! Thanks for taking the time to troubleshoot this issue, nice way to go! I'm wondering the same than @Rich_Laue. Have you?
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below, if you're using the Fitbit app for iOS, Android, or Windows 10:
If you're still unable to set up, try these troubleshooting steps:
Give this a go and let me know the outcome!
