brand new ionic,the firm ware has been updated and device restarted,
so now i start to add my choices,it took 5 attempts to get the clock face to change(and not the one i want),then it tells me to put on charge and leave alone to re-calibrate the sensors,,,,then i try and add an app(failed to install),try a different app(failed to install)....if this is how a new product behaves why was it released
Welcome to the Community @Slow-one! I'm sorry about the issues you're experiencing with your Ionic. I would like you to restart it and try changing the clock face again. Also, confirm you're using a compatible device and you have the latest version of the app which is 2.63 for Android and 2.44.2 for iOS.
Hope this helps! Keep me posted.
Best AnswerI have restarted it and changed the clock but it still says failed to install even though it had done it, its the same thing with the apps, keeps saying failed to install even though the app has been installed
