Exercise > Run > the default lap is always 0.50, I must go into the settings and configure it for 1 mile before every run.
My Ionic is on version 27.20.7.14, which I believe is the most recent version as of right now.
Should the lap settings save? or must you change them before every run?
10:57
09:38
02-04-2020
10:57
09:38
@fonefoo Welcome to the Community. Thanks for the details mentioned.
The lap settings should save and you shouldn't need to update them every time you're going for a run. In this case, I would like you to restart your Ionic and check if your lap settings are saved after this.
I'll be around if you have any additional questions.
