04-12-2022 18:41
04-12-2022 18:41
Hello everyone,
Honestly my needs are super simple. My doctor told me I need to get out and at least walk for exercise because I sit behind a desk for 9 hours a day. She told me I need to lose at least 3lbs by the next time I see her. All I want to do is track steps and track sleep. Should I get a Luxe or charge 4? Having a hard time choosing. I like the charge 4 but I don’t like the bulkiness of it
Best Answer04-12-2022 18:56
04-12-2022 18:56
Take the quiz. https://www.fitbit.com/global/us/products/find-your-fit
The Luxe is what I wear. The band is buttery soft and the display is bright and clear. It's all I need to keep track of the basics. Slender, too.
Best Answer04-13-2022 05:22
04-13-2022 05:22
@fluis I think that for your needs you might even consider a much cheaper Inspire 2.
Best Answer04-13-2022 06:40
04-13-2022 06:40
@Rufous44 which device do you have? The Inspire 2 is not as slender and comfortable for me as the Luxe. I have a family member with the Inspire 2 and it is currently $30 cheaper than the Luxe.
04-13-2022 20:17
04-13-2022 20:17
I own an Inspire 2 and my duaghter is currently using a Luxe. I find the Inspire 2 very confortable to use (not less than the Luxe) and the only lacks compared to the Luxe are the missing SpO2 and smart alarms.
However Inspire 2 has also the following advantages:
- use of capacitive buttons without relying only on touch screen (that I find very uncofortable on this tiny display)
- possibility to use it on hip via clip mode
- Find my device support (Tile integration)
- and last, but not less important, cheap price.
And yes, Luxe has a bright colored display, but this makes evident the terrible bezel/screen ratio and that makes it less attractive (how ironic right?)
Based on the above, really think that for the needs of @fluis the Inspire 2 (but even an old Inspire HR if still available from some retailers) could be an excellent choice.
