11-08-2023
09:00
11:08
EstuardoFitbit
11-08-2023
09:00
11:08
EstuardoFitbit
Completely dead won’t charge
Best Answer11-08-2023 11:08
11-08-2023 11:08
Hi there @Kwiksigns, it is nice to see a new member in the community.
Thank you for letting me know that your Fitbit Luxe is having some difficulties to properly charge.
As a first approach, I would like to try cleaning the charging contacts on the back of the device, using a toothbrush and some water.
I also need you to clean the pins that are on the charging cable, you will have to use a cotton swab and some disinfectant alcohol, making sure that no pieces of the swab remain on the pins.
Lastly you will need to connect it to another USB port or a UL certified USB wall charger.
11-08-2023 11:55
11-08-2023 11:55
