06-19-2021
17:27
08:28
06-19-2021
17:27
08:28
Is there a way to adjust the bracelet to a smaller size? It fits so loosely that I fear it will fall right off my wrist!
06-21-2021 08:25 - edited 01-07-2024 07:41
Hi there, @FaytheNHim79. Welcome to the Community Forums. I understand where your concern is coming from. @Nassra Thanks for your help!
Which band do you have? If you're referring to a gorjana bracelet:
If you have any other questions, see How do I get started with Fitbit Luxe?
Hope that helps.
06-19-2021 18:48
06-19-2021 18:48
The links nearest to the clasp open just like the clasp so that they can be removed to shorten the length of the bracelet.
Hope that helps.
