04-28-2021
19:33
15:36
EstuardoFitbit
04-28-2021
19:33
15:36
EstuardoFitbit
I’m pretty petite so I’d like to know the weight. The page lists the dimensions but not the weight.
I just weighed my Lunar White / Soft Gold version and here are the results:
- with band = 26g
- tracker only (no band) = 17g
Hello @InvisibleAna and welcome to the Help forum. I don't see it listed, either. But I think I can give you a reasonable estimate. The Charge 3 has a stainless case, like the Luxe and the pebble is about the same size. The Charge 3 pebble weighs 14g. Which Fitbit do you currently use?
Laurie | Maryland
Hi! I currently have a Flex 2, which is fabulously light, but well... ancient, and lacks the watch display which is all i want in an upgrade. I've tried on my sister's Alta HR, but found that too big and heavy for me. Not sure what either of those weigh, sorry.
@InvisibleAna As a long time Fitbit user, I was hoping I had an older model tracker lying around. You have or tried two of the trackers that I never tried! I wish I could have helped you more.
Laurie | Maryland
No worries! Thank you for being willing to help!
- with band = 26g
I heard reviewer on YT say the Inspire 3 was only 19 grams with band. So, I guess stainless steel added weight, which makes sense. I’m trying to decide between, thinner/smaller design and lighter Inspire 3. Is the size slight difference worth the added weight of the metal?
