06-04-2024
13:33
02:52
06-04-2024
13:33
02:52
Luxe battery draining quick
Best Answer06-05-2024 02:56
06-05-2024 02:56
Hi there, @KK3800. Welcome to the Fitbit Community Forums. I'm sorry to hear that the battery of your Luxe is draining quickly. I will do my best to help you with this!
If you haven't done so yet, please try the following steps:
Nonetheless, please bear in mind that as all rechargeable batteries age, they deteriorate to some extent and an older device will need to be charged more often than a new one. The best way of minimizing this effect is to avoid deep discharges of the battery. To maximize the overall life of your Fitbit device's battery, ideally keep it between 20-80%. Many people find that a daily battery boost works best ( e.g. giving it a 15 minutes charge while you are showering in the morning).
Best Answer06-06-2024 06:50
06-06-2024 06:50
Hello Marre,
I am having an issue where my Fitbit is not charging at all and would like to make use of my warranty to send the watch back.
However, I see that this function does not work quite properly and there is no way to contact the After Sales Service to be able to go ahead.
Can you kindly advise?
Best Answer06-17-2024 12:58
06-17-2024 12:58
My charger wasn’t working properly and I looked on my charger’s magnetic side and there was a sheet of metal so try it .
