My luxe shows critical percent needs charging or it just turns off. Once plugged in it starts and says it is at 88 percent. Needs to be charged at least 2 times in 48 hours. What is going on. I have restarted.
Thanks for any help.
In a situation like this the first question is always how old is your Luxe? As I am sure you are aware, all rechargeable batteries have a limited life span, and even the most carefully used batteries run out of charge recycles eventually. Very small batteries, such as in Fitbits, do have lower capacities than large ones. A battery that has been regularly allowed to discharge completely before recharging, or which spent a long period in deep discharge, will deteriorate more quickly.
I would recommend in the first instance to try giving your Luxe a small amount of charge each day - say 10 - 20 minutes, perhaps when you are showering and getting ready for work. Little and often charging is actually the best way of prolonging over all battery life.
If a short daily charge does not keep it going then I am afraid you will need to give it a longer boost, perhaps as much as daily as the device ages. Perhaps in the evening when you are relaxing with a book or in front of the television.
11:50
11:52
AndreaFitbit
08-06-2025
11:50
11:52
AndreaFitbit
Thank you for your email. I understand that about batteries, but my app
will tell me that it needs charging and is critical at 5 percent and when i
plug it in the display after restarting says 80 or 70 percent so the amount
of charge needed in always different.
Moderator Edit: Personal info removed.
Thanks for getting back to us @afarrell52. I'm sorry to hear that your Fitbit Luxe charging is not working properly. I'll be happy to assist.
Please confirm that you tried restarting your tracker with the steps of help article: How do I restart my Fitbit device?
Best AnswerI have restarted my luxe several times.
Thanks for getting back to us and for confirming that you have restarted your Luxe several times @afarrell52. I'll be happy to continue assisting you.
I appreciate your efforts. Our Team will be more than happy to have a closer look at this.
Please fill up this form with all the needed information. Our Team will reach back to you afterwards.
