08-09-2023
01:08
04:38
08-09-2023
01:08
04:38
My fitbit screen just stopped working randomly. I charged it fully there were just 4 dots on the bottom of the screen. I unsynced it frome my app & can't re-sync it due to the screen not working. How can I fit the screen. Nothing works. Tapping, charging, nothing.
Best Answer08-09-2023 05:05
08-09-2023 05:05
Hi @Sheshe567 Have you tried Restarting your Luxe? If not, give that a try. The other thing to try is to change the clock face in the app. Sadly if those don't help the it is probably dying
Helen | Western Australia
08-10-2023 04:40
08-10-2023 04:40
Hi there, @Sheshe567. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
As a first approach, please follow @NellyG's tips and recommendations as it seems like your Versa 4 ran out of battery. If afterwards you keep getting the Fitbit logo on the screen, please try the steps below:
If you can't get started with your Luxe, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
08-14-2023 18:36
08-14-2023 18:36
Thank you for this thorough response. I have been trying to fix this issue for months. I followed your steps and have a normally functioning luxe for the first time in almost a year.
