10-03-2022
09:42
09:49
10-03-2022
09:42
09:49
I bought this fit bit luxe two weeks ago and it worked fine for three days and then just started flickering.
I have tried most of the suggestions except for the clock face. I’m not really sure how to change it.
should I just send it back?
thank you for your help.
John
Hello there, @Modelboatsailor. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Luxe before reaching out. I understand where your concern is coming from.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face by following these steps How do I change the clock face on my Fitbit device?. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
@Modelboatsailor Sure thing! I'll be around if you need further help. 🙂
Best AnswerWhen this was happening to my mum's Luxe, support had me do a factory reset to her device which fixed it. Just make sure you sync up before you do it so you don't loose any steps.
https://help.fitbit.com/articles/en_US/Help_article/2216.htm
