07-08-2021
17:16
15:00
07-08-2021
17:16
15:00
Mine does the same thing. I can hardly see the display, steps are cumulative and not daily. The clock display is gone too. My other fit bit would light up when i looked at it and the luxe does not.
Hi @mcfarlandtravel Try restarting your Luxe and see ifbthat helps with the problems you are having. If that doesn't help then contact Fitbit Support
Helen | Western Australia
