06-28-2021
05:59
06:56
06-28-2021
05:59
06:56
My Luxe has stopped working after just 3 days.
The screen is black with a few dots at the top.
I am unable to reset it through the charger and the Fitbit help chat was unable to give me a solution.
Overall not impressed with this watch.
Anyone had this issue and found an answer?
Im now waiting for the battery to run out to see if this resets it!
06-28-2021 06:59
06-28-2021 06:59
Hi there, @Gillyhyde. Welcome to the Community Forums. We‘re taking into consideration your comments and sentiments with regards to our products and services.
Please bear in mind the information provided by our Support Team as your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for your Luxe's screen issue.
Have a nice day.
Best Answer06-28-2021 12:31
06-28-2021 12:31
Great I look forward to hearing from you soon 👍🏻
06-28-2021 12:34 - edited 03-20-2024 06:19
@Gillyhyde Thanks for your patience and understanding.
We look forward to getting you back on track soon.
Best Answer06-29-2021 15:03
06-29-2021 15:03
I have the same problem. My Luxe is only 24 hours old.
Best Answer06-29-2021 17:27 - edited 03-20-2024 06:18
Hi there, @Pinkhairgirl. Welcome on board.
So I can better assist you, would you mind giving me more details of the issue you're having with your Fitbit Luxe?
If you're having issues with the screen, please restart your Luxe as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer06-30-2021 04:17
06-30-2021 04:17
It’s quite frustrating isn’t it. Mines been frozen since Saturday now. 😵💫
Best Answer06-30-2021 06:15
06-30-2021 06:15
I am having the exact same problem with six dots on the screen, and mine also will not reset using the charging cable.
Best Answer06-30-2021 06:18
06-30-2021 06:18
I called 877-623-4997, and they are sending me a new one.
07-02-2021 04:03
07-02-2021 04:03
Calls to this number not being connected.
I would like a replacement as soon as possible
07-06-2021 02:02
07-06-2021 02:02
Still nothing….
