03-10-2023
09:51
06:22
03-10-2023
09:51
06:22
Has anyone had this happen? I have tried everything with settings. It stopped working 4 weeks ago, it isn't even 4 months old.
03-11-2023 06:23 - edited 06-03-2023 11:15
Hi there, @Jennybear6. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out.
In addition to the steps recommended by @Gr4ndp4, please also check Why didn't my Fitbit device alert me?
03-11-2023 03:07
03-11-2023 03:07
Hi, @Jennybear6, welcome to the community, number of settings affect vibration/notifications and you may have inadvertently changed one.
On your "Luxe" swipe down and ensure DND (Do Not Disturb) is off. Swipe down to sleep mode and ensure it is off. Swipe down to settings then up to quiet mode>check sleep mode is off. Return to settings, swipe up to vibrations and set on strong. Have a look at this article How do I get notifications from my phone on my Fitbit device?
Remember that if you do not want notifications while you are resting you will need to set DND or sleep mode.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
03-16-2023 05:28
03-16-2023 05:28
Thank you but I've checked all that you listed and still not working 😕
03-16-2023 05:54
03-16-2023 05:54
Hi, @Jennybear6, allowing you have investigated the points raised in my earlier post and that of @MarreFitbit I recommend you talk to "Customer Support" using the chat facility or phone for a prompt response. Before starting your call it's a good move to make a note of the steps you have taken and the result so the agent can move to a resolution quickly. You are almost certainly covered by Fitbit's "warranty" depending on where you live and provided you bought it from an approved seller. You may also want to review the returns policy of your retailer if you used one.
I hope this is helpful.
Cheers
Gr4ndp4 | UK
