11-20-2023
10:00
11:00
11-20-2023
10:00
11:00
on my Luxe watch, I see only yellow screen or large yellow rectangle. I have tried to restart the device and it did not work. Device firmware is 20001.188.58
Hello there, @singhikumud. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Luxe is stuck on a yellowish rectangle screen. Thank you so much for taking the time to troubleshoot your device before posting here. I'll be glad to continue assisting you.
In addition to the steps you've done so far, please try the following:
If you can't get started with the Fitbit device, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
@singhikumud Thank you so much for taking the time to follow the suggestions I've provided above. I understand where your concern is coming from.
To review whether your Luxe is defective, I've created a case to get you in contact with our Support Team about this issue. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you shortly!
We hope to get you back on track soon!
